Tire blew out? What is this garbage?
#41
well first its illegal to do what they did to you (in ny anyway) But if ur sidewall was chewed you might have driven on the tire itself, Almost no air in there would cause the rim to ride on the sidewall scraping away the inside. you sir are a dumbass it is illegal let someone leave a shop if they have run flat (The black shredded rubber in the tire)
They were correct in suggesting you replace it but, to force you into it isn't, At my shop we have a waiver form of sorts for situations like this. If the customer wants us to put a tire or whatever on their car that is dangerous we make them fill it out and thats that. like i said above it is illegal to put a tire back on the wheel if it has run flat so please tell everyone here were you work so they can stay away and they dont get put in harms way because you think it is alright to put a damaged tire that is ready to blow back on a car.
I'm pretty sure its illegal tho, But if you signed a work order or anything showing the purchase your out of luck I would think. i am positive that it is illegal to put a tire on that has side wall damage like that back on a car.
Go back there with a cop friend to scare them into doing right by you that will do no good at all they followed the law
like many people above said the reason why you could not have it repaired is because of the run flat in the tire that is rubber from the side wall if you were to hit a pot hole on a damaged tire like that it would have blew out instantly. the only warranty that i have seen that is good is the Discount Tire certs warranty if any thing happens to the tire and it is not repairable they will replace it for free. that does mean it has to be above 2/32 of tread which anything less than that is legally bald.
#42
i had a wheel that didnt hold air, so i had to constantly fill my tire up....eventually it just got so weak from being aired up and then driven flat and aired up and driven flat that the sidewall gave out....i had to have the wheel replaced, and the tire... blew at 80mph and the truck took a hard swirve...if it would have been a front tire instead of a rear, i bet the truck woulda wrecked
OP quit bitching, heres what coulda happened....next time maybe it will and then i bet you will get on here posting how pissed you are that they let you leave the shop on a bad tire...blah blah
no i wasnt missing lugnuts...took the pic half way through changing it
#43
jwog666
12-27-2021 08:09 PM
breaking
10-02-2015 01:27 PM
KingRando
10-02-2015 08:06 AM
