PCV Catch Can and Breather Filter
Old 11-30-2009, 10:09 PM
Black_GT_02
Black_GT_02's Avatar
Default PCV Catch Can and Breather Filter
Does anyone have a link for a nice catch can set up for my Procharger?
Also, i'm assuming the type of filter doesn't matter that I will be putting on the driver side valve cover?
Thanks
Black_GT_02 is offline
Old 12-01-2009, 01:29 AM
Frostbitten
Frostbitten's Avatar
the best is using AN fittings on the valvecovers with -10 hose coming from each valvecover to the catch can. to keep the oil from seeping out and running down the back of the valvecovers. you can use the same AN fittings that are used for fuel tanks, but youll have to remove the valvecovers to install them. If you dont want to do that you can try just using heater hose and clamps, but it may leak. Technically you only need to vent one cover, but i like ventilation to be evenly distributed. modularmustangracing.com makes a good kit, but it only comes with enough hose and fittings to vent one cover for $130. I think a real high quality setup will cost in the $200 range for both covers
Frostbitten is offline
Old 12-01-2009, 07:14 AM
Doogie65
Doogie65's Avatar
Check out this thread....
https://mustangforums.com/forum/4-6l...modaddict.html
Doogie65 is offline
Old 12-01-2009, 08:52 AM
99 GT vert
99 GT vert's Avatar
his valve covers are already off so that isnt a big deal
99 GT vert is offline
Old 12-01-2009, 11:17 AM
Black_GT_02
Frostbitten - Good information, i'll look into what you are saying and let you know if i have any further questions.
Doogie - thanks for the link man
Old 12-01-2009, 11:21 AM
Doogie65
Doogie65's Avatar
No problem as I have been researching these cans for quite a while. Just found another new one from Moroso on TMS and it looks to be another nice option. http://forums.themustangsource.com/s...d.php?t=478813
Doogie65 is offline
10-26-2015 05:01 PM
svfetter
10-05-2015 11:39 AM
Ipaman
09-22-2015 07:01 AM
Demodulates
09-18-2015 11:14 AM
Scottyboy187
SVT Forums
09-13-2015 10:23 PM
Quick Reply: PCV Catch Can and Breather Filter
