Coolant leaking.
I did a search, but didnt find a thread that quite described where I got coolant leaking from.
I seem to have coolant leaking around the water pump somewhere, it dosent leak alot, seems to be worse when I get on the gas a little. I cant tell where the coolant is comming from as it dosent always leak, all I can see is a coolant puddle on top of the block just behind the water pump. Im leaning towards a cracked intake manifold. Untill I can find the leak unless someone has any ideas I guess ill drive it untill the leak gets worse! lol.
foind someone with a coolant system pressure tester.i still have the factory all plastic intake on the wifes car and im getting a leak in the front coolant port areas.i think mines a leaking gasket .but i dont want to change it till i get the money to buy a aftermarket intake.just trying to figure out with one.
