Help... Huge Loss In Power...
Car sounds completely different at start up... almost hollow. RPM at idle are 700... Car is not putting out as much exhaust and is much quieter at idle and under load... very weak on acceleration...
Spun rod, Timing chain tensioner, maybe a collapsed lifter but I doubt it, bent or broken rod or pin.
Where you racing it the last time you drove it, or recently getting on it hard?
Could also be a problem with a clutch pack if the rivets broke free from a worn clutch.
When the ignition fires is when there is a big sound difference. (the first noise you here when you crank the key)
Mine idles around 700-750 as well. Any CEL? I agree checking the plugs too. Maybe you blew one out. Make sure they are all snug. If that was the case you should have a missfire code though.
nmra1965
Other Professional Racing
09-26-2015 10:46 AM
