Jacking up the rear end
Old 07-20-2005, 12:40 AM
BicketyBam
BicketyBam's Avatar
Default Jacking up the rear end
I was browsing through my owner's manual and it states to never jack the car up from under the differential. Oops. I've done it a bunch of times with a floorjack. I change my rear tires when I am going to drive on the highway and jacking both wheels off the ground at the same time is convenient. Is there another place to jack up the entire rearend besides the diff.?
BicketyBam is offline
Old 07-20-2005, 12:41 AM
sickspeedgt
sickspeedgt's Avatar
Default RE: Jacking up the rear end
i used 2 jacks under each side of the frame when i did mine
sickspeedgt is offline
Old 07-20-2005, 12:45 AM
badsp0rk
badsp0rk's Avatar
ORIGINAL: BicketyBam
I have the service manual. It states to use either the rear axle or frame to support the rear portion of the car. My car is currently jacked up on the rear axle in the back and frame in the front as I work on the exhaust. It was jacked up on the K-member... but there's no k-member on the car at the moment!
badsp0rk is offline
Old 07-20-2005, 12:55 AM
BicketyBam
BicketyBam's Avatar
If I am going to be under the car, or if it will be up in the air for more than 10-15 minutes, I jack it up from the rear differential and then put jack stands right where my subframes are welded on. I just want to make sure I am not damaging anything by using the rear end as a jack point.
Old 07-20-2005, 01:19 AM
JCstang01
JCstang01's Avatar
I do the same thing Bickety, I believe as long as your extremely careful not to hit or bend the diff. cover which will cause it to leak, there should be no problems. The rear diff. has been used as a jack point on every rear wheel drive car since the automobile got rubber tires.
JCstang01 is offline
mtgldr
02-03-2024 09:00 PM
zsmart
Convertible Tech
02-29-2016 08:33 AM
Ryan Fitzpatrick
09-14-2015 02:21 AM
fastbackford351
09-12-2015 09:42 AM
Dragonus18
09-09-2015 01:21 AM
Quick Reply: Jacking up the rear end
