Hope someone can help 99 GT
Have somebody or yourself go to the back of the car and see if you can hear the fuel pump when you turn the key one position before the engine cranks. You should hear the fuel pump for a few seconds.
Or if the car starts while you're cranking and someone is hitting the bottom of the fuel tank with a hammer you have a bad pump.
You can put a SVT pump in it is a direct drop in.
Sounds like a sticking IAC to me, BTW replacing the battery does not reset the computer. you can only reset KAM with a scan tool. IAC's are notorious for hard start concerns when cold. take it off and clean it with either spray carb or brake cleaner. make sure you get the chrome shaft that goes inside the solenoid good and clean, thats where they stick.
On to the issue at hand-
If the thing turns over just fine its obviously not the battery or starter.
If it starts when it's warm and not cold, it could be the IAC.
If it is now not starting at all, be it warm or cold- It's commonly the fuel pump as was stated before. Many of the tips listed about hearing it are accurate. If you can, check the fuel pressure on the rail.
Honestly, if you havent replaced them yourself, for the age of the car you should replace the fuel filter hands down, and likely the fuel pump if you can afford it. Im thinking its likely your fuel pump as you suspect.
Good luck!
1996cobraconvertible
SVT Forums
13
01-07-2016 04:50 AM
breaking
10-02-2015 01:27 PM
DreadPirateRoberts
09-26-2015 02:11 PM
