Control Valve Malfunction
Old 07-24-2005, 09:04 PM
SXGT
SXGT's Avatar
Default Control Valve Malfunction
My check engine light code is P1443 - EVAP Emission- Control System -Cntrl Valve Malf
what is a Control Valve?
SXGT is offline
Old 07-24-2005, 11:25 PM
SXGT
SXGT's Avatar
Default RE: Control Valve Malfunction
I found the info myself. I hope this helps anyone else who has this problem. NEVER IGNORE THE C.E.L.
This is the 3rd most common DTC. This code is described as “incorrect evaporative system purge control valve flow.” Ford’s purge flow sensor has been implicated as the source of the problem.
I hope that helps
found some more on it.
Ford On Board Diagnostics II, (OBD II) code P1443 means that the evaporative emissions charcoal canister purge sensor did not detect any flow when the canister should have been purging into the engine intake system. The purging, controlled by the computer,takes place when certain conditions are met, such as engine speed and temperature.What the computer operates to effect this purging is a 12 volt solenoid valve, solenoid means it has a moving piston in it which covers/uncovers ports in the valve so that flow does/does not take place. The "gunk" coming out of the charcoal canister will sometimes cause this piston to stick, resulting in purging not taking place when it should, the sensor in the purge hose detects this and sets a fault/trouble code and also turns on the "Check Engine" light. The electrical windings in these valves seldom fail, but anything is possible. To locate and check this valve, first find the charcoal canister, it will be a round or rectangular black plastic "box" with several different size hoses attached to it. If in doubt that you've found it, look at the bottom, there will be a plastic foam filter there---make sure it is not plugged up---. Once you've located the canister, start following the hoses attached to it. One will go towards the engine, follow that one along until you find the control valve that it attaches to, that's the valve that's not operating. Several things you can do now, just buy a new one and hope it is not the wiring or computer that's at fault. If you want to check it and the wiring, first, with key off, disconnect the two wire connector from it. Use a 12 volt test lamp, turn the key to "run" and check for current at both wires in the connector, one sould have current. Next, connect the test lamp between the two wires in the connector, start the engine and let it warm up, then run the engine up to around 1500 RPM or so, the test light should come on, if it doesn't, then it is the wire that was "cold" when you checked for power at the connector. or the computer. If the light comes on, then it is the valve. Remove it from the vehicle and clean it with an aerosol can of carburetor cleaner,use the "straw" that comes with the can and spray the cleaner into both hose nipples on the valve, alternatly spraying and shaking the valve. When you no longer get brown "gunk" coming out of the valve, reinstall it in the vehicle, but leave, if possible, the hose from the cannister disconnected. Start the car and let it warm up, (if need be), now raise the RPMs to 1500 or so. valve should now open and a vacuum should be present at the open nipple. If so, the problem is cured. On some OBD II equipped vehicles, repairing some problems will cause the computer to turn off the check engine light if the fault is no longer detected, other vehicles require that the computer be interfaced with and the code purged with a scan tool. Any questions, don't hesitate to ask. I'm curious as to what "Inspection Station" would not have sophisticated enough instrumentation to analyze the cause of a P1443 fault code.
SXGT is offline
GimpyHSHS
19
12-19-2023 01:12 PM
mrtrodonet
09-19-2020 03:12 PM
Bokeo
10-10-2015 08:28 PM
svfetter
10-05-2015 11:39 AM
breaking
10-02-2015 01:27 PM
Quick Reply: Control Valve Malfunction
