What are people running
i tried this on the pipes,boost, and juice and got few hits so i will try it on here. What is everybody's choice on a supercharger for their 2 valve mustangs. i am leaning towards a Procharger P-1SC but it does not give the kind of boost that i am looking for. anyways if you have an opinion on one or have one on your car let me know your thoughts. if you have one on your mustang please let me know your HP and TQ numbers, what kind it is, the boost level, what you have did to your car otherwise, qurter mile times, and what it cost for the whole thing. Probably think i am being nosy but trying to get a prospective on what other GT owners are doing as far as supercharging. thanks in advance.
RE: What are people running
If you have stock internals, 6-8 psi no matter what you put on. You can go a bit higher, but engine life may suffer. Personally, I like twin screw like Kenne Bell. Less piping to deal with.
heh.. how much boost do you want? stock, you're not going to run more than 10psi. even if you forge your bottom and beef up the rest of the car, that procharger or even a vortech v2 would put out close to 20psi. that's not enough?
https://mustangforums.com/m_533923/m.../tm.htm#534678
Should have ran a search first.
Like nanaki said, there are ways to turn up the boost on the procharger kits. You will hvae to talk to the folks over at procharger for more ifor on that. Sience they are intercooled, that will allow you to run more boost. I hear the air to air kits are more efficient at cooling the air (air to air is what you get w/ a procharger kit). i am not sure if the Kenne Bell can be intercoooled. I am sure someone will say if it can be
ORIGINAL: 9646gt
