hid fog light install help
Ok so my HID headlights are way easy and are done minus mounting the ballasts. However I haven't started my fogs yet because it appears I they have the two plug ins that go to the ballasts and then I have two pins that look like a negative and ground. What do I do with these?
01MGGT where did you decide to mount your ballasts for the fogs? i know one person said the bumper frame or something...did you do it different? im trying to get ideas where i could put it so that water won't get at it bad.
i want to know to as i am going to be installing these soon too.
I will let ya know when I finish mounting them I figured that's where they plug in. But I haven't looked at my connectors to see if the positive and negative on them is clearly labeled.
Got em in Have to get one replacement fog light bulb because the one on the pass side will not stay in the fog light. Won't latch in good like the left did! Looks great I cleaned the hell out of the inside of my front bumper and then used some strong 3m adhesive to hold the ballasts in there! Worked great and well hidden!
Diode Dynamics
28
05-26-2022 12:02 PM
inyadreems
08-21-2015 09:10 AM
