Replacing Intake Manifold
Old Jul 25, 2005 | 08:17 PM
ghoste's Avatar
ghoste
Default Replacing Intake Manifold
On a difficulty scale, what would you give this? I dremeled + JB welded a previous crack, now theres a ****ing HOLE with a steady stream of coolant spraying out.
I need to replace this asap. I will buy the manifold online, but just curious if anyone has tackled this project themselves.
Thanks..
Old Jul 25, 2005 | 08:40 PM
ghoste's Avatar
ghoste
Default RE: Replacing Intake Manifold
I just bought the improved manifold off 50resto.com
http://secure.50resto.com/product1.c...roduct_ID=2118
$189
Requires a new alternator bracket = $11
$216 and change w/tax
Old Jul 25, 2005 | 09:42 PM
sk8erdudex's Avatar
sk8erdudex
I did mine myself and it really wasn't that hard
Old Jul 25, 2005 | 10:28 PM
00silvergt's Avatar
00silvergt
I agree i did my intake tb and cai all at the same time and it was not hard at all.
Old Jul 25, 2005 | 10:38 PM
mustang_montana's Avatar
mustang_montana
i had a shop do mine, cost 200$ labor , manifold was around 200$ and then i needed new plugs/wires/bolts/gaskets etc and some new coolant total was around 500$. i couldnt do mine myself, it was during middle of winter. its a relatively big job, and time consuming but id definetly have tried it myself if it were warmer at the time. goodluck!
Old Jul 25, 2005 | 10:44 PM
GodAmGT00's Avatar
GodAmGT00
ORIGINAL: mustang_montana
Like he said.. It's not a hard job, just time consuming... A lot of little things need to be taken off in order... Not too many short cuts you can take, since it's at the bottom of the pile.. Just remember to keep like parts/hardware together, like using ziploc baggies and a marker... Best thing I can suggest... And put the parts you take off, lined up in the order in which they came off, and just try to remember orientation..
JT
95 Eagle Talon TSi AWD - 12.7 @ 103mph (R.I.P.)
00 Mustang GT - Back in Action, still too slow.....
Old Jul 25, 2005 | 10:52 PM
ghoste's Avatar
ghoste
Okay good .. Think I should replace the plugs with some iridium's while im at it?
Old Jul 25, 2005 | 10:56 PM
GodAmGT00's Avatar
GodAmGT00
Personally, I would... While you're in there, get all new gaskets, and any other things (thermostat), that you're going to remove and will be inexpensive anyway..
I don't believe in overkill... It doesn't hurt to replace older items with newer items, even if they don't add HP/TQ...
Just remember, if you need some help, ask someone on here, or check the manual...
JT
Old Jul 25, 2005 | 10:59 PM
ghoste's Avatar
ghoste
Ok, thanks to you all
BTW: What is the stock plug gapping for this motor?
Old Jul 25, 2005 | 11:04 PM
GodAmGT00's Avatar
GodAmGT00
Just check under your hood, should be listed next to your Belt routing sticker...
Don't remember off the top of my head..
JT
95 Eagle Talon TSi AWD - 12.7 @103mph (R.I.P.)
