ABS issue - C1095 code
Old Mar 15, 2010 | 09:20 PM
pikuoff's Avatar
pikuoff
Default ABS issue - C1095 code
My ABS light is on and my traction control is off. The car is a 2001 GT. I got it scanned from local club member and the code is:
C1095 - ABS hydraulic pump motor circuit failure
Any ideas on what I need to do to fix this? I can't really find much info online or on here about it.
All I have done so far is try unplugging the harness and plugging it back in. My buddy reset the code but it came back on.
Thanks!
Old Mar 16, 2010 | 11:05 AM
pikuoff's Avatar
pikuoff
Bump...
More info:
I checked the fuses under the hood last night and they all tested fine. I know I checked all the fuses under the dash last November when the light first came on and those were good too. When my buddy ran the scantool on it, we could hear the pump run but it was intermittent...not sure if it was supposed to be like that or stay on through the duration of the test or not. I was wondering if it was just the ABS module. I found a website where you can send in your ABS module and they would fix the circuitry on it for like $150. Much cheaper than $4-800 for a new module! But if it is definitely the pump, fixing the module won't fix the mechanics of the pump.
Make sense?
Old Mar 16, 2010 | 01:13 PM
MidNightRunner's Avatar
MidNightRunner
I've had the same problem on my 01 GT for about 2 years now. I can't for the life of me figure this one out. Its just not worth all that money to start replacing ABS components one at a time till I find the fault.
If anyone else has had this problem please help us out!
Old Mar 17, 2010 | 07:16 AM
pikuoff's Avatar
pikuoff
Anyone with any past experience with this code?
Old Mar 17, 2010 | 07:53 PM
pikuoff's Avatar
pikuoff
Anyone?
Old Mar 18, 2010 | 08:56 AM
pikuoff's Avatar
pikuoff
Gonna pick a pump/module assembly off a 02 GT from a local junkyard this weekend. Will let yall know if that fixes it.
Old Mar 19, 2010 | 04:33 PM
MidNightRunner
That would be much appreciated. I hope that's all it takes man, good luck!
Jb145700
Aug 21, 2022 06:37 AM
TfcCDR
Sep 14, 2015 12:08 PM
MusicCity615
Sep 12, 2015 07:05 AM
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
zanemoseley
Sep 6, 2015 12:58 PM
