NEED HELP WITH DIAGNOSTIC ON 2000 GT!!
hello everyone, ive got a 2000 GT with a Saleen supercharger. the service engine light recently came on. ive had the codes pulled (P0174 and P0171) running lean on bank one and two. ive checked for vacum leaks, replaced fuel filter, replaced air filter, cleaned mass air sensor, checked PCV valve. also its idling rough, it goes from about 600RPM to approx 1400RPM. however only does this when its warmed up. if anyone has had this problem or would suggest what to do that would be great. appreciate any useful information. thank you!
no i havent messed with the IAC yet. the SC has about 5k miles. its got 32lbs injectors from saleen that came with the kit. not sure on the fuel pump. the computer was reflashed by saleen but it hasnt been on the dyno with the SC.
trashxtrash
09-20-2015 10:49 PM
