nitrous helpp
yeah try putting the nitrous jet a little farther from the maf. if you're still having problems, find a tuner in your area (which you should do anyways just to make sure you're staying safe).
quick question, was your car recalibrated for the bigger injectors?
no but im worried about somthing else the plug ferthest back on the drivers side was bent over and the one fertherst back on the pass side gap was closed do u think i need ne rod bearings i didnt loose oil pressure or over heat do u think if i slap a new intake on ill be ok?
You have a blown up intake and smashed and bent plugs. I would pull the heads and check the pistons. As stated a dry shot NEEDS to be before the maf. I think nitrous outlet makes a nozzle designed to go through the tip of the filter and not freeze up the maf.
well i talked to my teacher (i go to uti) he said that i could of gotten a peice of my intake in the cylindar tht could of done tht to the plugs so he suggested a leak down text but if i dont have one so im gunna do a compresson test it should atleast give me some idea if it just needs an intake
