shift kit?
Old Aug 1, 2005 | 05:04 AM
ROB 98GT's Avatar
ROB 98GT
Default shift kit?
would a shift kit do anything different than the diablosport predator ? my car is an auto. thanks!
Old Aug 1, 2005 | 09:54 AM
DIVER8374's Avatar
DIVER8374
Default RE: shift kit?
Will it do anything different, is the question. The answer is yes and no. No it will not do anything different, they both increase line pressure and make the shifts firmer and harder. Yes the shift kit actually changes the springs and other things in the trans to mak e the shifts harder/firmer. The predator just use the computer to modift the shift pressure.
I started out with just useing the predator to modify my shift pressure and points and it made a big difference in hoe the car sifted. Then I had the shift kit installed and the difference was greater than just useing the predator. (Before the shift kit was installed I set it back to stock with the predator). I drove around for about 2 weeks then went in with the predator and up my shift pressure a little more and I really like how the car shifts now!!! It really grabs second and third.
Old Aug 1, 2005 | 12:05 PM
98LS1's Avatar
98LS1
As Diver said, they both increase line pressure thusly increasing shift firmness. From the way I understand it, unless you actually re-program your computer, you will not shift any faster with a shiftkit, just harder, the same for a handheld programmer. You actually have to modify your PCM to allow for .00 seconds between shifts. It's set to shift sloppy, so you can't feel it shift. I guess women like it this way....?
Anyway, two things I can see with a shift kit over a programmer is that, the kit "beefs up" some of your internal parts in the tranny, and it also allows you to downshift the car w/o worrying about hurting something. So you can be in the best gear to begin a race, w/o waiting for the car to downshift. Most auto trannies don't like to be manually shifted unless you have a manual valve body though.
I wouldn't run a programmer AND a shift kit to increase pressure, one or the other should do fine.
I only ran a programmer in my car when it was auto and had no problems with it.
Old Aug 1, 2005 | 03:27 PM
Demonite23's Avatar
Demonite23
exactly how do you downshift using a shift kit. Cause if you drop it in 2nd in an auto you still have to manuelly place it in drive after that. I donno, maybe i dont fully understand the concept of the shift kit.
Old Aug 1, 2005 | 03:58 PM
98LS1's Avatar
98LS1
You can manually select your gear that you want. Without a shift kit, it makes this harder on the tranny itself. The tranny will still shift when it's designated to in the computer. Most people do not understand this though. In other words, you're going from a 50 kick, you can put your auto in 2nd and then when you nail it, just shift to D, or OD, w/e. It'll shift when it's supposed to and you started in your powerband. Whereas just leaving it in D or OD would waste time as the tranny would have to downshift on its own before you would begin accelerating.
Old Aug 1, 2005 | 04:56 PM
sandcracker21's Avatar
sandcracker21
well i have a question then, is doing wut you just described "bad" for the tranny of an auto
without a shift kit? if so why?? it doesnt seem to make any sence that a shift kit would
all of a sudden make it "not bad" anymore
Old Aug 1, 2005 | 05:06 PM
98LS1's Avatar
98LS1
ORIGINAL: sandcracker21
Most auto's aren't meant to be manually shifted. The need time to build line pressure before they shift. Shifting it manually doesn't allow it time to build this pressure. Besides, it's gonna shift when the computer tells it to anyhow. If you go WOT and shift from 1 to 2 at 3k rpms, it's still gonna run all the way up til when it's supposed to shift as long as you stay WOT.
With the kit coming with beefed up parts, it's just easier on your tranny when you decide to manually put it in a gear.
I'm by no means an expert on this. If someone else wants to chime in, go ahead.
Old Aug 2, 2005 | 12:11 AM
ROB 98GT's Avatar
ROB 98GT
thanks for your help!
jwog666
Dec 27, 2021 08:09 PM
Thunderball
15
Nov 22, 2015 11:49 PM
Lethaldosage423
Oct 19, 2015 12:12 AM
Explosive
Oct 2, 2015 07:45 AM
