replace transmission
Old Aug 1, 2005 | 10:27 AM
vbmustang's Avatar
vbmustang
Default replace transmission
Well everybody I am having trany problems. 4th gear seems to be going, when shifting into 4th it will pop right back out....some times. It dosent happen every time but I think it is only going to get worse. Were and what type of trany is a good replacement. Also I am not looking to spend a fortune. Thanks everybody
Old Aug 1, 2005 | 10:35 AM
02StanGT's Avatar
02StanGT
Default RE: replace transmission
How much is a fortune to you?? Here is one. Another. And yet another, though more expensive than the others.
Old Aug 1, 2005 | 11:51 AM
GodAmGT00's Avatar
GodAmGT00
ORIGINAL: vbmustang
Sounds like a bad syncro in 4th gear.. You could get yours rebuilt, w/ better internals for probably less than buying a brand new bad *** tranny... Not sure what kind of Tranny shops you have in your area..
JT
95 Eagle Talon TSi AWD - 12.7 @ 103mph (R.I.P.)
00 Mustang GT - Back in Action, still too slow.....
Old Aug 1, 2005 | 01:10 PM
vbmustang's Avatar
vbmustang
the trany has already been operated on by Ford about 2 years ago. one of the shift forks broke and had to be replaced. The problem with opening up the trany is it is aluminum, and when put back together the case dosent seal like new and can result in more problems than you started out with.
Old Aug 1, 2005 | 09:12 PM
2000GT4.6's Avatar
2000GT4.6
ORIGINAL: vbmustang
I will be going to pick up my car either tommarow or the next day, after a trans swap. The grand total is now 3400 dollars (installed) with almost 700 of that install costs. It was supposed to be 400 bucks, so I dunno wtf happened there.
I did have to get a new bellhousing and yoke along with the trans, and I upgraded the clutch to a spec stage 3 and put in a new flywheel, plus a firewall quadrant and clutch adjuster.
I put a TKO 500 in btw.
Old Aug 2, 2005 | 10:16 AM
vbmustang's Avatar
vbmustang
Hey 2000GT4.6, how much did each part cost?
Old Aug 2, 2005 | 02:09 PM
silvergt's Avatar
silvergt
Im having that same exact problem when going into fourth , does anyone know were to find good internals for a rebuild on my 2000 gt trans
Old Aug 2, 2005 | 02:54 PM
mk636's Avatar
mk636
VB, buy the transmission and I will help you put it in.
5.0muscle
Jan 11, 2016 01:17 PM
MusicCity615
Sep 12, 2015 07:05 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
Art161
Sep 9, 2015 10:33 AM
vintageaion
Sep 8, 2015 10:45 AM
