Quick Speedo???
i have a 2003 gt and im am goin to replace my speedo cluster with a 2000 saleen that goes to 200 and mine goes to 150. will the speed be reading right wth the saleen one since it is the entire cluster.
o ok see i thought it would work fine since it has the gears inside the whole cluster i thought. but wouldnt i just find out what gear ratio a 2000 saleen had and sent my computer to that
Actually I might be wrong, but as far as I know, there's a magnet or laser at the wheel that sends a signal to the ECU and that sends another signal to the cluster for your speed reading. I would think you'd need to reprogram your car computer for the new speed ratios, but like previously stated, I could be incorrect.
For the '96 through '98 models the instrument cluster counted those pulses and drove the speedometer/odometer--that's why a new drive gear or SpeedCal is needed to correct the speedometer.
On the '99 through '04 models the PCM does the counting and sends the speed data in digital format to the instrument cluster. That's why you can fix it in the tune on the newer models.
You need to run the instrument cluster flex-circuit that came with your car, or the PATS will activate and you will not be able to start the car.
The instrument cluster computer and the PCM are components of the PATS, that are "married" by a shared identifier at the factory. This can be reset with the IDS if you find an operator with the knowkedge.
autoedit
Sep 27, 2015 06:37 PM
Sep 25, 2015 06:30 PM
