P0401 EGR sensor !
Old May 14, 2010 | 05:44 PM
MaKaVeLi's Avatar
MaKaVeLi
Default P0401 EGR sensor !
so i had this code in the predator which is p0401 which is: EGR flow insufficient detected ( after i fix the diver side headers cause there was leak,however, i did search about this code and alot of websites said that it caused by the egr sensor which is this:
after i instal it the SES light didnt go ! so i cleared it, and then apear again !
so why this sensor didnt fix my problem?
is it the wrong sensor to replace?
or there is further problem to be fix?
Old May 16, 2010 | 04:11 PM
MaKaVeLi's Avatar
MaKaVeLi
update:
i just replace the EGR valve and still the check engine didnt go ! i cleared it and still apear again ! so how can i solve it ?
Old May 17, 2010 | 03:44 AM
cliffyk's Avatar
cliffyk
TECH SAVANT
Here's what the 2002 shop manual says about P0401.
Work each potential issue, check to make sure the EGR pipe is not stuffed up...
Old May 18, 2010 | 03:22 PM
E_LOW's Avatar
E_LOW
when i had that code, it was cause the vaccum control solenoid
Old May 29, 2010 | 05:08 PM
MaKaVeLi's Avatar
MaKaVeLi
first i fix the headers in the drivers side because there was a leak..... then this code show up.... i changed the egr senser and still not gone... i changed the egr valve and still the code shows up !! the garage guys ( both electric and mechanic) said they tried to fix it but every thing seems fine ! only that the electric guy said that it cloud have an over flow air which i couldnt understand........ so what should i do guys ??
Old May 30, 2010 | 01:22 AM
MaKaVeLi's Avatar
MaKaVeLi
how did you fix it? i meant which parts did you change/ where are this problem location.....
jwog666
Dec 27, 2021 08:09 PM
mrtrodonet
Sep 19, 2020 03:12 PM
Dathan
Oct 5, 2015 05:52 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
TfcCDR
Sep 14, 2015 12:08 PM
