Erratic Idle when stopped and AC is on...
Old 05-27-2010, 04:46 PM
99redmustang
99redmustang's Avatar
Default Erratic Idle when stopped and AC is on...
I have a 1999 GT and I am having really bad idle surges when the AC is on and I come to a complete stop. The idle is fine when I have the AC on and the car is in in traffic...the idle surges from 300rmp to about 1400rmp and does this for the duration of time that I am stopped....sometimes it almost shuts off...
I've cleaned the MAF, clean the air filter (K&N), replaced the IAC valve, the EGR valve, PCV valve and I have a new ECM (about 3 months old). I have had an EVAP test done within the last year or so and no leak (I had the prior to the EVAP test). Do they check for VAC leaks during a EVAP Test??? Am I not checking something??? Could it be low on freon or something.
It only happens when I come to a stop!!! Any advice...Thank
99redmustang is offline
Old 05-29-2010, 08:19 PM
liljojo4711
liljojo4711's Avatar
mine is doing the exact same thing... 99 gt
liljojo4711 is offline
Old 05-30-2010, 06:10 PM
FrostByte
FrostByte's Avatar
Make shure the A/C is fully charged & not cycling on & off when you are stopped.
FrostByte is offline
Old 08-24-2010, 09:42 PM
meshow99
meshow99's Avatar
Was this problem ever fixed? If so, how. Mine does it. 00 GT Vert.
meshow99 is offline
Old 08-24-2010, 10:28 PM
defconfire
defconfire's Avatar
Check your IAC your Spark plugs and your Fuel Filter.
defconfire is offline
Old 09-05-2010, 10:52 PM
sinister99GT
sinister99GT's Avatar
mind did it when the refrigerant was at low levels, recharge it and i bet it is fine,as long as there are no bad leaks.
sinister99GT is offline
4cylinderplus2
10-09-2020 07:45 PM
TCStangerv6
10-11-2015 05:57 PM
svfetter
10-05-2015 11:39 AM
Quick Reply: Erratic Idle when stopped and AC is on...
