steering problems
Old Aug 6, 2005 | 02:58 PM
badsp0rk's Avatar
badsp0rk
Default steering problems
well, i installed my new headers.. and i had clearance issues with my steering shaft.
i tried to bang a dent into the headers, but it's not possible unless i take the headers out and try that way. so i figured the only other way to fix the problem would be to buy a new steering shaft with better clearance.
looked around and found the flaming river steering shaft, thanks to help from a member on here.
ordered it from steeda, and the thing came in today. looked like it was the same diameter and such as the old steering shaft, causing me to question if it'd fit or not, but as they advertised that it ought to fit and give me more clearance i went along with the installation anyway.
and here i am now; the universal joint on the shaft will not fit into the rack and pinion steering assembly, since the shaft of the steering shaft is banging next to the header.. i managed to get the thing half way in and now it won't move anymore, in or out. with enough banging i'm sure i can get this thing out, but there's no way that this will give me more clearance. if anything, it gives me less clearance because there's a nipple for grease right where my header is.
so, my questions are as follows:
1) due to false advertising, steeda ought to take this product back, correct? i mean, they say right on the webpage that it will offer more header clearance, and neglect to give dimensions. i ordered it assuming it'd be skinnier and fit properly, but it's not even close.
2) any other suggestions as to how i can fix my steering problem now?? i'm thinking maybe i should grind down the old steering shaft where it's touching the header; it's only like 1mm of clearance issues, at most, with the old steering shaft.
Old Aug 6, 2005 | 03:24 PM
JD1969's Avatar
JD1969
Pro. B.S. caller outer
Default RE: steering problems
I would not grind on your shaft LOL. Tkae the header out and bang a small dent in it. I know its a pain but it needs to be done.
SSRFUZZY
Members Other Vehicles
Jan 6, 2016 08:22 PM
uberstang1
Sep 20, 2015 06:42 PM
rksnow1
Sep 14, 2015 08:46 PM
BOBCATJACK
Sep 14, 2015 02:18 AM
Sep 8, 2015 11:50 AM
