exhaust ping ????
exhaust ping ????
Hey everyone,
I drive a 2002 GT all stock except for flowmaster mufflers.
Just recently i've noticed a ping/pop while warming up my car. It only happens about every 20 seconds. Then goes away once the car is warm.
Its loudest on the drivers side, can't tell if its coming from the motor or exhaust.
I've been told that its the exhaust pinging from the metal warming up.
Any ideas ??? it never used to do this before.
thanks
thanks
As to the OP's issue it could well be the noise he is hearing is caused by the down pipe heating and expanding. I have heard the heat shields on catalytic converters make metallic pingy/poppy sorts of noises as well; often if one or more of the spot welds holding them on breaks...
I don't think the noises you are hearing are fuel grade related in any way. Octane related "noises" typically occur on warm/hot engines, under load; and almost never (really, really almost never)) on cold engines while idling/light load.
As you described the noise and the circumstances of of its occurrence I'd go with thermal/mechanical causation...
junior04
09-28-2015 10:53 AM
09-24-2015 09:18 PM
