Swishing noise from motor? Thoughts??
First, I always replace my belt on Fords with a Gatorback. They seem to help with slipping, 2nd gear belt chirping, etc. It sounds like bearing going out in one of your accessories? It can make noise when heated up because heat can break down the slight protection of any grease that may help with the bearings when it's cold.
Is it the noise that comes and goes in the video? Like you can hear it at :13 :15 :19 :21
sec?
Take some WD-40 and start spraying as well. Spray all the pulley's one at a time and when/if it goes away then that's the prob. It's random because it does not seem RPM dependent. If it was a constant noise or even at a faster feequency then I would immediatly point to a pulley bearing or something belt driven.
sec?
sec?
sec?
