CCRM/FUEL PUMP ?
Old Aug 8, 2010 | 06:48 PM
slo97's Avatar
slo97
Default CCRM/FUEL PUMP ?
Ok i have no power at my fuel pump plug or pump shut off and i have no power coming from the green and yellow wire that is coming from the pump relay inside the ccrm. im assuming this means my ccrm is bad. my pump does not come on by key but will come on when you touch a 9 volt battery to it but car will not start with the 9 volt powering the pump and i have no fuel at my schrader valve with 9 volt so is this because the lack of volts or could pump also be bad my friend said the 9 volt should start car. my friend has a ccrm out of a v6 mustang i have heard it will work and i have heard it will not the one in my car is f6sf-12b577-aa and the one from the v6 is f6zf-12b77-aa i will be home later this week and be able to try it and see i was just wondering if it will at least give me power to my pump i have no ac and i can hard wire my fan. any help or ideas would be great because i am stumped my car just died all the sudden oh my fuse is good and i have power to the fuse box
jwog666
Dec 27, 2021 08:09 PM
CS2007
Jun 25, 2019 09:45 PM
Bokeo
Oct 10, 2015 08:28 PM
1996cobraconvertible
SVT Forums
Sep 30, 2015 02:01 PM
mrappe
Sep 26, 2015 10:16 AM
