Getting close to completing my DOHC swap
Old Aug 17, 2010 | 09:43 AM
MikeInCape's Avatar
MikeInCape
Default Getting close to completing my DOHC swap
I am just about finished with a DOHC Cobra motor swap into a 98 GT. I am going to be using my stock computer and harness and have it tuned.
I am planning on buying a turbo kit with my next paycheck. Will I be able to start the engine being a DOHC turbo on a SOHC stock ECU? I know I need to get it tuned, but can I start it to test and make sure it is running right with no leaks before getting it programmed?
I do have a diablosport predator... Should I adjust any settings myself before starting?
Please advise.
Thanks,
Mike
Old Aug 17, 2010 | 10:47 AM
uberstang1's Avatar
uberstang1
Chupacabra
When i did my swap, i drove it 3 months with the gt ecu and tune before i got to the dyno to realize it wouldnt open the IMRCs
Old Aug 17, 2010 | 11:06 AM
MikeInCape's Avatar
MikeInCape
Good to know...
I am in the process of removing my butterflies and welding the holes, so the IMRC wont be an issue for me.
Old Aug 17, 2010 | 02:32 PM
BraMas's Avatar
BraMas
Be careful welding the holes you are taking a chance of warping the IMRC plate. That is why most people use a really good epoxy
Old Aug 17, 2010 | 03:24 PM
smitty2919's Avatar
smitty2919
You can buy IMRC delete plates. They are the same dimensions as stock IMRC's but have no plates in them. Something to look into price wise and risk of warping the stock ones.
Old Aug 18, 2010 | 07:06 AM
devongarver's Avatar
devongarver
So how sad is it that I had no clue wtf IMRC's were until I googled it and found a "how-to" on cleaning them over at modded mustangs...I guess I need to read up on 4v's...
Old Aug 18, 2010 | 07:52 AM
smitty2919's Avatar
smitty2919
Like my dad always says...the more things you have the more can go wrong. They are good when they work...but when they leak or stick closed/open they suck.
I would have went with the deletes on my Mark8 but not for that price and it was a DD so there was no performance mods to offset the loss in low end tq if I put them in.
69MustangCoupe393cid
Oct 3, 2015 10:33 AM
LivingInThePast
Sep 16, 2015 12:20 PM
rdog69t
SVT Forums
Sep 13, 2015 06:16 PM
MusicCity615
Sep 12, 2015 07:05 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
