sub frame question
Old 09-04-2010, 09:46 AM
97gold
97gold's Avatar
Default sub frame question
today i went to go put my sub frame's on when put them on to test fit the front was pretty good but the back had about a inch gap between the rail and the torque box on the instructions said to weld the back on first then jack up the front until the rail sits flat against the car does that sound right by the way i have full length connecters
97gold is offline
Old 09-04-2010, 09:50 AM
98redstang
98redstang's Avatar
your frame could be bent...
98redstang is offline
Old 09-04-2010, 10:28 AM
97gold
97gold's Avatar
no i dont think so its like that on both sides
97gold is offline
Old 09-04-2010, 01:15 PM
98redstang
98redstang's Avatar
it could still be bent even if its like that on both sides. The middle could be saggin? YOu know what i mean?
Old 09-04-2010, 02:11 PM
DIY
DIY's Avatar
Make sure the car is level and the suspension is fully loaded before welding in the connectors. If you 're using a lift, make sure its the drive-on type. If you 're using jack stands, be sure to place them directly under the rear axle and place ramps under the front wheels. Again, you want the suspension/wheels to support the total weight of the car. If the car is already properly supported and the gap is still there, then yes, something is probably bent. This is a faily common situation with unibody cars, especially Mustangs built before 2005.
DIY is offline
Old 09-04-2010, 07:17 PM
97gold
97gold's Avatar
well i had on a car.Do y'all think i should bend the sub frame's to make them work or what
97gold is offline
Old 09-04-2010, 10:48 PM
98redstang
98redstang's Avatar
i get the second part but what does well i had on a car mean? not just to be a d!ck just wanna know if your tryin to ask something so we can help you out.
Old 09-04-2010, 10:55 PM
Soldier GT
Soldier GT's Avatar
I'm not the sharpest tool in the tool shed but seems as though, if you bend/cut/alter any kind of suspension piece (especailly subframes) you would/could somehow affect the integrity of the piece..Just my two cents..
Soldier GT is offline
Old 09-04-2010, 10:57 PM
DIY
DIY's Avatar
What method did you use to lift the car? Did you use jack stands, ramps or a car lift?
DIY is offline
Old 09-05-2010, 08:29 AM
97gold
97gold's Avatar
im sorry i mean i had it on a car lift
97gold is offline
Quick Reply: sub frame question
