Curious
Old Sep 20, 2010 | 02:51 PM
0949er's Avatar
0949er
that article must of been talking about fulll boost.
my 3.33" started making boost at around 2500 rpms, whereas my 3.6" pulley starts to make bost around 3k
Old Sep 20, 2010 | 03:23 PM
Warrior1876's Avatar
Warrior1876
Thanks for the responses
Old Sep 20, 2010 | 05:23 PM
ddmsgtr1's Avatar
ddmsgtr1
If it's the 5.0 article about their F1a fed 2v, forget everything they said, that articles basically worthless. They have far too big of a pulley on there for what that blower is meant for.
Old Sep 20, 2010 | 05:27 PM
piledriver's Avatar
piledriver
Banned
Originally Posted by oxfordgt
It all depends on your setup with a centri. My novi 2000 was pullied to make 23lbs of boost. At 2500rpms I was making 10lbs and climbed to 23lbs by 6500rpms. It hit harder then some turbo cars I rode in.
Hey Oxford, what size pulley do you have, to make so much boost. 23 lbs. is a lot. Do you think my car, with the Cobra shortblock, Cobra crank, and forged internals could handle 23lbs of boost/ I would have her retuned, of course.
Thanks
Old Sep 20, 2010 | 10:22 PM
ddmsgtr1's Avatar
ddmsgtr1
Ox would know better than me, but I would think you're shortblock should be fine, but you're fuel system's really going to limit you there.
Old Sep 20, 2010 | 10:43 PM
oxfordgt's Avatar
oxfordgt
I was running 23lbs of boost on 93 octane and meth injection.
@piledriver I ran a 2.8 s/c pulley and a 10% overdrive crank pulley. I had to run an 8 rib setup and upgrade the tensioner. Yes your engine will handle it but you will need meth and your fuel system wont even come close.
Old Sep 21, 2010 | 05:04 AM
piledriver's Avatar
piledriver
Banned
Thank you, yeah I thought I'd have to get into the fuel system somewhat, maybe 60 lb or more injectors, what else would I need? I have another fuel pump in the garage, I think it's from a Focus, but that probably wouldn't cut it.
Old Sep 21, 2010 | 07:29 AM
oxfordgt's Avatar
oxfordgt
For that kind of power you would need either a triple pump setup with gt40 pumps or a return style system with a big external pump. I would switch to return style since fuel will start to cook in the rails at that level on a returnless.
daltron
Apr 28, 2016 08:10 PM
mungodrums
Oct 7, 2015 04:01 AM
2016PP
Sep 23, 2015 09:51 AM
movielover40
Sep 10, 2015 03:34 PM
