Popping noise in engine (video included)
Old Oct 21, 2010 | 09:51 AM
jg42122's Avatar
jg42122
Default Popping noise in engine (video included)
Ok I have finally got my stang finished from close to a yrs worth of mods, and paint. I did the complete pi swap with ported heads, and I added the bbk shorty headers, x-pipe flow master exhaust, and the bbk throttle body, cold air filter and well basically any other decent bolt-on or mod I could find.
Now everything is together and running pretty good but but I am having a popping noise, for example if the car is idle and I give it gas as I push down on the pedal all is fine, but when I release pressure on the gas that is when I hear this loud metallic sounding pop. Sometimes it's just one pop sometimes 2, also it is not idling correctly and, I the engine has a ticking noise possibly a lifter? Thank you for any suggestions. Sorry the video is shaky in parts I just threw something together for everyone to hear.
http://www.youtube.com/watch?v=3QBKdMKjsCo
Old Oct 21, 2010 | 09:58 AM
a_penquin's Avatar
a_penquin
Sounds like an exhaust leak, and a rocker maybe. Do you have cams, are they degreed correctly? The clunks sound like bad news to me.
Old Oct 21, 2010 | 02:24 PM
jg42122's Avatar
jg42122
Hi no I did not degree the cams, I think the ticking noise may be a lifter, or a rocker, but I am not for sure. Thank you
Old Oct 21, 2010 | 05:02 PM
0949er's Avatar
0949er
sounds like a knock to me, not a pop.
does it increase w/ rpm? (like 800 rpm and give it gas to 1000 RPM)
Old Oct 21, 2010 | 05:15 PM
jg42122's Avatar
jg42122
Hi no it only makes the knock/popping sound between first and second while driving, or in idle after giving it gas. It only makes the popping/knocking sound when I let off the gas not while I am giving it gas. Thank you
Old Oct 21, 2010 | 07:38 PM
dwtjr3's Avatar
dwtjr3
are the cam gears tightened and torqued to the right specs? May want to double check mine made the same noise when i put my cams in and it turns out my cam gears weren't tight
Old Oct 21, 2010 | 07:43 PM
jg42122's Avatar
jg42122
Thank you for your reply I will be checking this tomorrow. It very well possibly could be the head shop put everything else on wrong so this very well could be a possibility. If you don't mind me asking which noise are you referring to the ticking, popping, or just the whole thing in general.
Thank you
Old Oct 21, 2010 | 07:45 PM
dwtjr3's Avatar
dwtjr3
the ticking/ popping noise. When I put my cams in and heard that noise on the first start up scared me to death I thought i broke my car haha but I was very happy whne i found out the cam gear was just loose
Old Oct 21, 2010 | 08:02 PM
jg42122's Avatar
jg42122
Well I am going to give it a try first thing in the morning. Thank you
Old Oct 21, 2010 | 08:52 PM
SilvrStang's Avatar
SilvrStang
If you just installed the cams on that car its normal if you didnt lube it up and all. Mine did it for several hunder miles and the noise went away once everything got lubricated.
