Issue flushing cooling system
Old Oct 22, 2010 | 07:36 PM
DreamerGT's Avatar
DreamerGT
Default Issue flushing cooling system
Ok I emptied out all the coolant and ran water through it until it came out clear(with the engine on and off), and when I go to refill the system the water will not drain(it just sits in the overflow tank). So I turn the engine on, the water will start move up then bubbles and go's back down. It will keep doing that until the car gets warm, then it will start moving up and start pouring out of the overflow tank. Any ideas on whats causing this?
Old Oct 22, 2010 | 07:58 PM
Bmitchell373's Avatar
Bmitchell373
Kinda sounds like the thermostat wasn't/didn't open. Was the car at OT when doing the flush?
Old Oct 22, 2010 | 08:16 PM
DreamerGT's Avatar
DreamerGT
sorry but what is OT?
Old Oct 22, 2010 | 09:43 PM
Bmitchell373
Sorry, Operating Temperature. Everyone else does it and I get lost. lol
Old Oct 23, 2010 | 09:09 AM
DreamerGT's Avatar
DreamerGT
oh ok, and yes I open the drain when water started pouring out of the tank. Also someone told me that I should lift the front end more while flushing so I will try that out too.
Old Oct 23, 2010 | 09:47 AM
ctgreddy's Avatar
ctgreddy
Sounds like there's air in the system. I did what you did, kept topping it off with water until it came out clear, then let all te water drain, closed the valve, and then put straight coolant in, about 2 gallons, which should of gave me close to a 50/50 mix. I had the front end lifted, and after you get the coolant in I would rev it to 2500 for 30 seconds then let it idle for a minute or two, and repeat. This is the best method ive found to get all the air out of the system.
Old Oct 23, 2010 | 05:29 PM
SilvrStang's Avatar
SilvrStang
Def air in the system . Gota burp the system out and get all that out of there.
Old Oct 23, 2010 | 06:30 PM
DreamerGT's Avatar
DreamerGT
So when the coolant starts to over flow out of the tank do I just let it go until it stops?
Old Oct 23, 2010 | 07:31 PM
StriderTacticaL's Avatar
StriderTacticaL
Interesting...I always thought that any air in the system would just slowly bubble out. I hard there is a such thing as a giant pocket if air around the water pump which causes it not to move any water. Not sure if thats your issue.
I would just add water until the resevoir is halfway full and let it idle for a decent amount of time and watch the water level. It it rises, let it. I think eventually it will start to go back down and then slowly add water as needed.
Old Oct 24, 2010 | 02:08 PM
DreamerGT's Avatar
DreamerGT
Ok I did it again, with the front lifted up. It still doing the same thing, I noticed when It gets up to temp. the water rises and starts boiling. So Im going to let it cool and keep trying until I get all the air out the system.
MusicCity615
Sep 12, 2015 07:05 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
cbird1177711
Sep 3, 2015 08:43 PM
cbird1177711
Sep 2, 2015 08:51 PM
