whistle when slight throttle just started
Old 10-26-2010, 01:02 AM
cisurfer
cisurfer's Avatar
Default whistle when slight throttle just started
this all started after i did my egr delelte. before that i took off the lower manifold due to the non replaceable gasket leaking coolant and used rtv which fixed the leak. while doing that i cleaned all the intake runners in the manifold and the heads with carb cleaner and toothbrush they were nasty. I also replace the o ring on the injectors and cleaned them. installed new intake to head gaskets, new plenum gasket, egr gasket along with the delete plate, iac gasket. re-routed the vacuum lines so it emliminated the egr vacuum lines. when i give it slight throttle it whistles breifly then stops and then when driving it will whistle with partial throttle. I have a c&l plenum, bbk 75mm tb and bbk cai. i know ppl say this is normal but this just started since all this and ive had this setup for 2 years without this problem so its not normal. ive sprayed carb cleaner to look for vacuum leaks but i cant find any its driving me crazy
cisurfer is offline
StalkerGT
09-25-2015 02:41 PM
Pyrate Dave
09-10-2015 07:30 PM
zanemoseley
09-06-2015 12:58 PM
5.0 kevo
09-03-2015 06:24 PM
whatsup62
09-03-2015 01:38 PM
Quick Reply: whistle when slight throttle just started
