help disconnecting the fuel line on top of the tank
Old Nov 2, 2010 | 02:57 PM
jvog's Avatar
jvog
Default help disconnecting the fuel line on top of the tank
Are there any tips or tricks to get this damn line off. I'm using the tool but it just doesnt want to come apart
Old Nov 2, 2010 | 03:22 PM
WhiteFoxGT's Avatar
WhiteFoxGT
Resident Ford Troll
push the line in as far as it'll go, insert the tool then pull/twist
Old Nov 2, 2010 | 03:35 PM
jvog's Avatar
jvog
Still no worky
Old Nov 2, 2010 | 03:37 PM
a_penquin's Avatar
a_penquin
The lines suck, make sure your using the right size. Push in the line, push the tool into the connector and slide both back at the same time. You really just have to keep screwing with it till it works or breaks.....
Old Nov 2, 2010 | 03:47 PM
v8.GT Stang's Avatar
v8.GT Stang
there is spring lock you also have to push the line toward the tool .. and it should come off when u pull it back again if not .. try to push it harder from both sides
Old Nov 2, 2010 | 04:27 PM
jvog's Avatar
jvog
I said **** it and took the line off in the filter. On a side not I broke the lip on the big blue plastic thing.wtf is it and how much is it gonna cost me
Old Nov 3, 2010 | 09:14 PM
jvog's Avatar
jvog
psssst! THe little blue cylinder going into the tank is the fuel tank vapor valve. what is the big blue one?
Old Nov 5, 2010 | 01:49 AM
jvog's Avatar
jvog
you guys are killin me here
Granatelli Sales
Jan 20, 2020 12:34 AM
TfcCDR
Sep 14, 2015 12:08 PM
96stang3.8
Sep 10, 2015 06:42 AM
raleigh05GTO
Sep 4, 2015 07:09 AM
5.0 kevo
Sep 3, 2015 06:24 PM
