Lowering 04 GT
Lowering 04 GT
Could I lower my 2004 GT by cutting the springs with a saw? Ive seen people do it on other cars...
Also, What do you think about the steeda springs? How much lower does it make you go...
RE: Lowering 04 GT
You sure could..... will it ride good..... probley not....is it the best way to lower your stang......Not at all..
The Steeda spring, Eibach, MM are a lot better way to go if you want to lower your car. Do a search on here about the type of spring that you want to use and I am sure that you will find some info on them.
RE: Lowering 04 GT
ORIGINAL: XbcSharpShooter
thanks for the answer, sounds like I should do it.
The only reason I try to go with steeda is because Im 10 minutes from their main facility.
