just curious
Old Dec 8, 2010 | 03:48 PM
EI-03-GT's Avatar
EI-03-GT
Default just curious
does any one know if the Venom 24lb fuel injectors will work with the stock connecter or if i would need to get a adapter to make them work? Also will the stock fuel rails work? i dont plan on maxing out the fuel injectors i am just using them for one stage of the build. what is the limilts of the fuel pump as well?
just to make things easier i am going to tell you what i plan on doing and why i am asking. I plan on buying either a mmr 600 or 900 longblock with trickflow heads. the cams ill be using for this stage in the build are XE270AH from comp cams. knowing the mods i have in mind for this point in the build what should i do as far as fuel system upgrades?
Old Dec 10, 2010 | 06:15 PM
cliffyk's Avatar
cliffyk
TECH SAVANT
If they are EV1 or EV6 body style, and have the Jetronic/Minitimer connector they will fit/work. Click here for more about that...
daltron
Apr 28, 2016 08:10 PM
mungodrums
Oct 7, 2015 04:01 AM
2016PP
Sep 23, 2015 09:51 AM
movielover40
Sep 10, 2015 03:34 PM
