lower compression
Old Dec 10, 2010 | 03:40 PM
EI-03-GT's Avatar
EI-03-GT
Default lower compression
what affect would a lower compression ratio have on a N/A engine?
Old Dec 10, 2010 | 04:38 PM
Xemeth's Avatar
Xemeth
Why the **** would you do that? You'd lose power.
The only reason to lower compression is for boost.
Old Dec 10, 2010 | 05:44 PM
EI-03-GT's Avatar
EI-03-GT
haha im not doing it! i was just looking at some parts and the compression drop with the different piston heads and i didnt know what affect they would have on a N/A engine. i know that its used in a FI engine to reduce stress on the bottom end just wasnt sure what other affects it would have. thanks
Old Dec 10, 2010 | 06:06 PM
cliffyk's Avatar
cliffyk
TECH SAVANT
It would produce less power, with nothing but f/i or juice available to increase it.
BTW, on f/i engines lower compression ratios only indirectly reduce bottom end stress--directly it allows more optimally advanced ignition timing without irregular flame fronts and pockets of destructive detonation.
lincolnshibuya
Jul 5, 2020 03:05 AM
baddog671
Jul 26, 2016 01:20 PM
UrS4
Oct 3, 2015 06:23 AM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
NYstang
Sep 30, 2015 09:56 PM
