Fog Lights Question
Old Jan 18, 2011 | 08:05 AM
Spotty's Avatar
Spotty
Default Fog Lights Question
I recently purchased a 2000 Mustang Gt. I noticed that the little LED indicator in the switch does not come on and I have no fog lights. I crawled under the front and saw one wire not even plugged in and the other one was hanging out with the remains of a broken bulb stuck in. I'll clean it all up and put in new bulbs. My question though is I can not locate where the fuse might be if that also is the problem in the end. I looked in the book and they list a relay under the hood....is that it? Any help would be appreciated!
Thanks....Jeff
Old Jan 18, 2011 | 09:35 AM
Jazzer The Cat's Avatar
Jazzer The Cat
Retired Moderator
It might be blown, so take it to Rado Shack and have it tested if you don't know how. I have some info on fog lights and modification, so peep ***THIS*** thread.
Jazzer
Old Jan 18, 2011 | 10:32 AM
Spotty's Avatar
Spotty
Thank You for the info. I also noticed the LED in the Traction Control switch doesn't work, but the switch itself does toggle the feature in and out. Soooo, probably will pick up a new switch for that. Saw some on-line for about $30-35 bucks....so not too bad I guess. Thanks Again....Jeff
Old Jan 18, 2011 | 06:37 PM
cliffyk's Avatar
cliffyk
TECH SAVANT
The fog lamps are powered by fuse #27 in the battery junction box (under the hood by the battery)--they are the only thing powered by that fuse.
Old Jan 18, 2011 | 09:32 PM
Spotty's Avatar
Spotty
Thanks! I'll be sure to check that fuse if they don't work when I am done.
Jeff
Old Jan 24, 2011 | 08:02 PM
donnieb83's Avatar
donnieb83
Curious if you got yours working? I have a similar issue. thanks
Old Jan 26, 2011 | 09:00 AM
Spotty's Avatar
Spotty
Yes I did. I cleaned up the connectors that were either hanging out or had a broken bulb. Put in new bulbs, ( 899) pulled #27 fuse and checked ( good) pulled the relay and bench tested it (good), took the switch out and took it apart and bench tested it. Contacts were good but both the little bulbs for illumination and indication of (fog lights on) were burned out. Replaced both bulbs, put all back together and all works well. I would guess any problems with the fog lights would be in the above area's unless a mouse chew got to something.....Good Luck!
Old Jan 26, 2011 | 10:55 AM
donnieb83's Avatar
donnieb83
^^^Awesome! Thanks!
Nick Oliver
Oct 17, 2018 04:22 AM
zachary1988
Sep 4, 2015 03:04 PM
cbird1177711
Sep 3, 2015 08:43 PM
amandahchase
Sep 3, 2015 10:09 AM
cbird1177711
Sep 2, 2015 08:51 PM
