Washer fluid pump
Old 02-03-2011, 01:01 PM
getafewlives
getafewlives's Avatar
Default Washer fluid pump
Before I go digging around in my car, I have a quick question.
Where is the pump/motor for the washer fluid on a 1999 mustang? When I press the button to squirt fluid, it only kinda dribbles out, instead of full on spraying out.
getafewlives is offline
Old 02-04-2011, 03:46 PM
cliffyk
TECH SAVANT
cliffyk's Avatar
In the driver side fender well, toward the front--you have to remove the wheel and inner fender splash guard...
cliffyk is offline
Old 02-04-2011, 04:01 PM
WhiteFoxGT
Resident Ford Troll
WhiteFoxGT's Avatar
Pop the hood + cowl and check the nozzles. Pop the feed line off and make sure its pumping out good. Could just be a broken rubber hose or clogged up nozzle causing the crappy flow
WhiteFoxGT is offline
Old 02-09-2011, 09:36 PM
getafewlives
Will do, thanks.
jwog666
12-27-2021 08:09 PM
Bokeo
10-10-2015 08:28 PM
1996cobraconvertible
SVT Forums
09-30-2015 02:01 PM
mrappe
09-26-2015 10:16 AM
09-25-2015 06:42 PM
Quick Reply: Washer fluid pump
