STICKY CALIPERS
Old Feb 11, 2011 | 05:41 PM
kbrlane's Avatar
kbrlane
Default STICKY CALIPERS
My brother has a 2001 Mustang GT and from new the front calipers put pressure on the discs so you could hardly spin the tire while jacked up.My other brother put them on his '94 Cobra Pro Street car,same thing so he got new calipers,they still drag.What causes this? and whats the cheapest way to fix it?
Old Feb 11, 2011 | 06:49 PM
JRad405's Avatar
JRad405
Sometimes the pistons on calipers freeze which is probably what is happening in your case. The options are to rebuild the caliper and replace the psitons or get new caliper.
You could try finding a junked mustang and getting those calipers. That is probably your cheapest bet.
Old Feb 11, 2011 | 06:54 PM
03gt04mach1's Avatar
03gt04mach1
There is always some slight drag on the rotors from the pads. As long as it's not pulling from one side and the brakes aren't getting hot, and wearing quickly, there should be no problems. But, if you can't turn the wheel, with the car up in the air, that may be a problem.
Old Feb 11, 2011 | 07:43 PM
Sxynerd's Avatar
Sxynerd
99 till about 03 have a horrible tendency for the soft line to collapse and lock up the calipers. Change the rubber pressure hose and I will "gar-un-tee" it will fix the problems
It even happened to my 03.
Old Feb 11, 2011 | 10:55 PM
kbrlane's Avatar
kbrlane
Jrad,we tried new calipers.
03GT,the front tires turn very hard-too tight.
sxynerd,thats interesting,will check it out.
Thanks for input !
Old Feb 12, 2011 | 10:46 AM
WhiteFoxGT's Avatar
WhiteFoxGT
Resident Ford Troll
what he said. Always check the lines before you slam calipers on it, and even when you replace calipers its always good to replace the lines as well. I've been burned before on a collapsed line I thought was a caliper problem
Old Feb 16, 2011 | 08:31 AM
kbrlane's Avatar
kbrlane
Brother #2 put on new steel braided lines...Still looking for answers.
Old Feb 16, 2011 | 09:41 AM
WhiteFoxGT's Avatar
WhiteFoxGT
Resident Ford Troll
Bad hub is the only thing I can think of, assuming the rest of the hydraulics in the brake system are good
Tivo304
Aug 28, 2023 12:19 PM
mungodrums
Sep 29, 2015 09:18 PM
mdj89
Sep 23, 2015 08:49 AM
maestro1024
Sep 21, 2015 02:40 PM
inyadreems
Aug 21, 2015 09:10 AM
