Cam And Nirtous?
Cam And Nirtous?
i am planning on ordering some comp stage 2 cams. If i also run a 100 shot through the car will the cams hold? im guessign they would i just saw that COMP also sell cams made for boost and nirtous so i was just wondering if i had to buy those if i was planning on running some nirtous.
Thanks
Thanks
I would shy away from a nitrous specific cam because you won't be spraying all the time. A nice NA cam will be perfect for nitrous as long as the exhaust duration and lift are decent. I'd look at the CMS stage 2 NA cams if you want a cam that will be a really good on the nitrous as well as off the bottle.
The comp stage 2's that you are referring to will do just fine on the nitrous, but i would personally look into other cams. MHS and CMS make better speced cams IMO. Call Nick at MHS and ask him what he thinks about those Comp cams. You'll be surprised at what you will learn.
junior04
09-28-2015 10:53 AM
