Engine bogs out in 4th and 5th.
I said " it sounds like spark blowout", which often occurs only at the higher loads associated with higher gears--this has nothing to do with boost or no boost, it's combustion chamber pressures, swirl velocities, and a number of other factors. Have you ever read Heywood or Taylor?
Also note that I said "It sounds like", I did NOT proclaim that as the problem.
im just saying that blowout would need some blow, a vortech just doesnt have it right into 4th...id expect you to know that.
Wow, not sure where all the hate is coming from vulture54, I think cliffyk has a very good point, he has more knowledge and has probably helped more people on this site than anyone else. He may or may not be right in this case, but your dumbass sure as hell doesn't know. For you to criticize only shows ignorance on your part. Your posts don't even make sense! I think I know what your trying to say, but you are to vague in your responses.
I think my point is that spark plug blowout is associated with a load...he said he can't even use 4th or 5th...no load, no blow out...o yeah cliff, and I don't know you, but I'd think a tech wouldn't even produce such a diagnosis given the facts of the post
by the way 2000gt, blow me, I'm glad your coming to bat for your boyfriend and all, why don't you help solve the ****in problem.
That would be the clutch slipping...
