2000 GT Tuning
Old Apr 9, 2011 | 06:42 PM
cliffyk's Avatar
cliffyk
TECH SAVANT
Originally Posted by neo8222
Ok got the box code and tune file. The file name does not reflect a box code from your list though; came back as CVAF1B2.GTG2.pcm so box code GTG2.
That's a "2001" box code, it may be late 2000 production, or a dealer may have reflashed the PCM.
I have that OEM tune and the Delta Force template, let me make a SF base tune and see what it has changed--are there any mods on the car mow?
Old Apr 10, 2011 | 02:34 AM
neo8222's Avatar
neo8222
as far as i can tell it's showroom stock except for me pulling out the factory mufflers and welding in resonator pipes, and removing the silencer on the intake... not like it's actually needed lol. but no nothing significant enough to cause issues.
Old Apr 10, 2011 | 12:05 PM
cliffyk's Avatar
cliffyk
TECH SAVANT
Any new-edge Mustang running the stock tune, needs a tune...
Old Apr 11, 2011 | 08:14 AM
neo8222's Avatar
neo8222
true, haha. I'm temped to make 2 tunes for my friends car one normal one, and one with a speed limiter set as low as it goes
Old Apr 12, 2011 | 03:29 PM
neo8222's Avatar
neo8222
any updates?
Old Apr 12, 2011 | 03:41 PM
cliffyk's Avatar
cliffyk
TECH SAVANT
any updates?
I have been tied up with my real clients (the ones that pay the bills), I'll try to get to it tonight or tomorrow...
Old Apr 13, 2011 | 01:36 AM
neo8222's Avatar
neo8222
i just told my friend the something like that.. shouldn't bug the guy doing something for ya for free. no rush on it in any case, we did run into another snag though, his factory plastic intake bombed today. the crossover pipe for the coolant cracked WIDE open. so we gota get the new intake installed before the weekend or the plans to hit the strip are gone. went with the ford racing piece that has the aluminum crossover pipe and a set of fel-pro gaskets for like $250 shipped next day air
Old Apr 19, 2011 | 01:52 PM
neo8222's Avatar
neo8222
bump...
Old May 1, 2011 | 11:13 PM
pals911's Avatar
pals911
i am his friend that owns the car not tiring to rush u i appreciate u doing the tune for me but it has been a few weeks and kinda eager to get it just wondering if u knew when u would be abel to get it done
Old May 2, 2011 | 08:56 AM
cliffyk's Avatar
cliffyk
TECH SAVANT
Sorry for the delay, between real work and ongoing illness I have been "up-to-my-ears"--thank you for the nag...
To clear things up a bit, I had not offered to make a tune for you (I do not do "mail-order" tunes¹)--just create a tune using Special Forces V2.x and report what it changed when the base tune was created, here is that.
I used SF and only the following changes from the default base tune settings:
  • Box Code: GTG2;
  • Transmission: Manual;
  • Fuel Octane: 93;
Here's what Special Forces changed when the base tune was created:
Scalers:
  • Global Spark Adder: +2.0°;
  • MAF Max Volts: 4.99 (from 4.79);
  • WOT Aircharge Correction Factor: 1.95 (from 1.1);
Tables:
  • Spark Borderline: add 2.0° above 79% load, from 500 to 6000 rpm;
  • Stabilised Open Loop Fuel: richen mix @ 80% load up to 2000 rpm,
    lean the mix from there up;
There are also various non-performance related changes related to adaptive learning, optimisation of OBD2 monitoring, etc.
This is, as I expected, 99.44% of what any canned or mail order tune set to your mods would look like. Your friend can create this tune using Special Forces and the selections I listed above.
You may wish to further tweak the rpm range timing on SF's Fine Tuning dialog. Sneak up on it in each range 0.5° at a time, and listen for pinging on hard acceleration--when you hear it back off 0.5°.
Do not muck about with fueling unless you have a wide band O2 system.
¹ - Special Forces' tunes, generated by entering your car's specs in the input dialogs, are as good as any "canned" tune and as most any customised mail-order tune. Any further optimisation requires that each of the tuner's senses (sight, taste, smell, touch, hearing) be able to be applied directly to the project.
firecoyote
Sep 27, 2015 02:37 PM
ThatJuanStang
Sep 25, 2015 08:01 AM
12bigredstang
Sep 24, 2015 10:43 AM
trashxtrash
Sep 20, 2015 10:49 PM
rksnow1
Sep 14, 2015 08:46 PM
