Code P0460
Old Feb 20, 2012 | 08:49 AM
  #21
bopiela's Avatar
bopiela
Cliffy,
it read FUEL000 last time I ran this. Will run it again to see if that's changed. But that tells me there is a short. I checked under the dash but am a little lost on how to trace a wire from the dash to the fuel tank... I don't know where it runs, ha ha.
Thanks for the continued help...
Old Feb 20, 2012 | 09:05 AM
  #22
cliffyk's Avatar
cliffyk
TECH SAVANT
Originally Posted by bopiela
Cliffy,
It could also be a bad fuel level sensor, "waterlogged" float, or wiring in/near the tank. Using the resistors as indicated will let you know which--if the gauge reads full with the 160Ω resistor and empty with the 15Ω resistor then the wiring between the connector and the instrument cluster is OK...
Old Feb 20, 2012 | 09:12 AM
  #23
bopiela's Avatar
bopiela
Oh, OK. Well I will see what happens then. Thanks Cliff.
Old Feb 20, 2012 | 09:33 AM
  #24
cliffyk's Avatar
cliffyk
TECH SAVANT
By doing that you'll isolate the issue as being either fore or aft of the connector...
Old Feb 20, 2012 | 10:40 AM
  #25
bopiela's Avatar
bopiela
Do i just attach the resistor to the one wire? I've never used these before. I tried googling it, but get different answers all the time...
Thanks!
Old Feb 20, 2012 | 11:26 AM
  #26
cliffyk's Avatar
cliffyk
TECH SAVANT
They would be connected across the connector pins as shown below, but instead of the Ford test box:
Old Feb 20, 2012 | 02:44 PM
  #27
bopiela's Avatar
bopiela
Thanks Cliff. Will post when I resolve or figure out where problem is.
Old Feb 21, 2012 | 03:15 PM
  #28
bopiela's Avatar
bopiela
Cliff,
Just a heads up question in case. If I put the resistors on and the gauge works (full and empty at the specified ranges) then the problem would be the float because it is sending the proper resistance? If the gauge still doesn't work, I have to trace the wire and find the short?
Thanks again.
Old Feb 21, 2012 | 04:58 PM
  #29
cliffyk's Avatar
cliffyk
TECH SAVANT
Yup..
If with the resistors the gauge operates as it should then everything from the connector forward is OK, the problem is from the connector back toward the tank. Check for pinched/frayed/broken wires etc, or the sending unit is bad, float stuck/"waterlogged"/etc...
Old Feb 22, 2012 | 11:05 AM
  #30
bopiela's Avatar
bopiela
Well I assuming I did the test right, I found out that I have a wiring issue somewhere.... So now I don't know if I'll just live with it, or try tracing that wire... Since I had the entire interior out, it is very possible I clipped it/pinched somewhere along the line last winter and it just took some driving to bounce it around and render it useless..... Guess I'll check the easy areas first and see if anything comes up....
