98 and 04 car issue
98 and 04 car issue
I have a 1998 GT car with a 04 GT engine and tranny installed
The car in 1998 was an automatic and now it has a standard transmission. The speedometer shows irrational speeds when only doing about 10mph. So I guess it is connected because the miles keep increasing (at a very fast rate BTW)
How can I fix this? Do I have to replace the original AUTOMATIC Speedo and cable for one out of a STANDARD 1998 or am I SOL because I have a 2004 motor installed?
Thanks
Thanks
The engine has nothing to do with the speedo on a 98, its controlled by a plastic speedo gear in the transmission, I'm assuming the rear end has gears installed or your trans already had a speedo gear that doesn't match your existing rear gear ratio. You either need to get a replacement speedo gear to match the rear gear ration and if thats not available you'll need the speedcal box.
The engine doesn't but the TRANNY does. The original tranny was an AUTOMATIC and now it has a 5 Speed tranny. Would that be the issue? I think yes. Should I try to find a Speedo from a 5 Speed 1998 and the issue could be resolved? or should I try to calibrate the ratios?
If the transmission is also a 2004 I believe they have a different speed sensor in them (electronically driven) vs the mechanical one in a 98. I do believe everyting still hooks up but they read crazy fast, and I'm not sure what an appriopiate fix is but I'll ask some of my buddies and try to get an answer.
Might Want to give Dallas Mustang a call and see if this will fix ur problem
http://www.dallasmustang.com/mustang...DED-RANGE/7626
Or if they have an application for your trans
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
