Throw out bearing question.
Old May 8, 2011 | 09:44 PM
95SHO's Avatar
95SHO
Default Throw out bearing question.
I just bought a 2001 GT and the previous owner installed a clutch before I bought it but he installed the clutch disc backwards and the throw out bearing failed.
I bought a new clutch kit and it's going in tomorrow, I'm not sure how to get the throw out bearing of the the clutch release lever. Actually it's the clutch release lever I don't know how to remove.
Old May 8, 2011 | 11:46 PM
Cornbread52's Avatar
Cornbread52
If I remember correctly, once you have the transmission out, the lever pulls off the bearing. The bearing can then be pulled off the input shaft.
Old May 9, 2011 | 02:08 AM
cliffyk's Avatar
cliffyk
TECH SAVANT
Here's a photo of what it looks like, that may be of help:
On the right you can see the spring clips that hold the lever on the pivot ball, once the tranny is out pull the lever forward a bit and away from the pivot--it will pop off the ball. Install it in the same manner, in reverse. Lightly grease the ball, and socket in the lever, and pop the lever onto the ball--make sure the spring fingers do not get deformed.
This photo also shows the proper mounting of the TOB.
Here's a clear shot of it being installed, this on a TKO so they took the photo without the tranny mounting on the bell housing--on the 3650 you have to work it over the input shaft, not a big deal...
Old May 9, 2011 | 06:27 AM
Jazzer The Cat's Avatar
Jazzer The Cat
Retired Moderator
The Cliffster with action photos... noice!
mrtrodonet
Sep 19, 2020 03:12 PM
6bangr
Feb 15, 2016 07:40 AM
KingRando
Oct 2, 2015 08:06 AM
Drastang
Sep 30, 2015 03:48 AM
Offendant
Sep 23, 2015 07:21 PM
