Normal oil pressure readings?
Old May 17, 2011 | 10:19 AM
MyGt03's Avatar
MyGt03
Default Normal oil pressure readings?
Just installed a Speed of Sound gauge pillar and couple Glow Shift gauges. Always run Mobil 1 full synthetic and had just changed oil. On first start up, oil pressure reads 80-90psi. Gauge goes up to 100psi. After going for first ride, as engine warmed up, oil pressure went down.
My question is, how low should it go when sitting at idle at normal operating temperature? I grabbed my camera and got a clip in HD. Will post the link to the video I posted on YouTube. Don't mind my blaring music. Clip is focused on pressure gauge.
http://youtu.be/8Iu37e0diyE
Last edited by MyGt03; May 17, 2011 at 10:21 AM. Reason: Embedding video didn't work
Old May 17, 2011 | 10:39 AM
0949er's Avatar
0949er
when I start up cold I run 78 psi
Once it warms up, (really warms up) I run from 18-20 psi. As soon as any gas is given the pressure gauge will go up past 50 and climb with rpms
Old May 17, 2011 | 10:59 AM
MyGt03's Avatar
MyGt03
Yeah, That is what mine does. Being how the factory pressure gauge doesn't move, I never really knew what pressure I should expect. Thanks...
Old May 17, 2011 | 04:45 PM
96meangreengt's Avatar
96meangreengt
my autometer gauge reads 85-90psi on start up and when idleing in town at around 210 degrees (water temp) it reads about 25psi then jumps straight to 50+psi when accerating
Old May 19, 2011 | 09:46 AM
MyGt03's Avatar
MyGt03
Thanks for the info guys. Im taking it as just a cheap gauge and cheap sending unit. Glow Shift electrical oil pressure gauge, 52 bucks on eBay. Compare that to an Autometer electrical gauge at 212 bucks. For the full sweep Ultra-Lite. As long as I know I got oil pressure, I think I be fine...
Old May 19, 2011 | 12:05 PM
cliffyk's Avatar
cliffyk
TECH SAVANT
It's perfectly normal for the pressure to be that high at start-up and fall back as the oil and engine heat up. With the engine hot the pressure should be 20-45psi at 1500 RPM.
Old May 19, 2011 | 05:59 PM
96meangreengt
where did you look at autometer gauge's that the oil pressure gauge was $212
i bought this one
http://www.latemodelrestoration.com/...Pressure-Gauge
only $70
Tivo304
Aug 28, 2023 12:19 PM
bconboy
Sep 21, 2015 12:52 PM
Emblazoned
Sep 3, 2015 10:45 PM
whatsup62
Sep 3, 2015 01:38 PM
amandahchase
Sep 3, 2015 10:09 AM
