SOHC 2V to DOHC 4V
Old Aug 20, 2011 | 09:32 AM
wlp165's Avatar
wlp165
Default SOHC 2V to DOHC 4V
Would there be any fitment or installation issues with going from the 4.6L SOHC 2V to the 4.6L DOHC 4V? I was thinking of getting the replacement DOHC 4V engine from fordparts.com (it would be a remanufactured complete engine assembly). My Mustang is the 2001 Bullitt GT with the 4.6L SOHC 2V.
Outside of the engine, there are some similarities between the Bullitt GT and the SVT Cobra of that year (transmission make, final drive ratio, gear ratios, 8.8" rear axle, throttle body (dual 57 mm unit), mass air meter diameter)) that would make me think the engine swap should go pretty well.
Old Aug 22, 2011 | 05:36 AM
uberstang1's Avatar
uberstang1
Chupacabra
Youll need a cobra ecu and harness, a cobra ecu and modified GT harness OR re use your GT computer with either a cobra harness or modified gt harness with a TUNE AND IMRC deletes if its a B head motor. Depending which 4v it is you may need a throttle and cruise control cable. Other than that its a direct swap in assumming you have a complete 4v setup (MAF/Injectors/ correct flywheel/ etc etc)
Old Aug 22, 2011 | 08:34 AM
jeh4269's Avatar
jeh4269
+1^ I would say an 01 4v, keep your ecu and just modify your harness,then get it tuned.I think that would be a fairly easy swap and it should make it easy for the tuner to do his job.
Old Aug 25, 2011 | 11:39 AM
BlackMage's Avatar
BlackMage
I dont think anyone posting in this thread has ever done a 4v swap....
Old Aug 26, 2011 | 07:55 PM
jeh4269's Avatar
jeh4269
I would agree.
4.6LPoppy
Dec 28, 2006 02:47 AM
xnavekx
Apr 25, 2006 11:31 AM
04blkstang
Jan 6, 2006 12:43 AM
td1989
Apr 19, 2005 10:53 PM
dustinpolcz
13
Sep 11, 2004 12:42 AM
