Suspension? Spings or control arms? idk either
The S197 Chassis is VERY ridged right from Ford, so no need to do ANY support for it at all. Throwing a new "K" up front is about all that race cars do, beyond the mandatory roll-cage for open-track.
Jazzer
Jazzer
Why is it already so rigid? And they dont ever bother adding like LCA's or springs, or shocks/struts or anything? Wouldn't that still help them a lot at auto-x? What do you mean by "race" cars? Surely these guys that are serious about auto-x do more than drop in an aftermarket K.
If you don't midn the increased NVH of spherical bushings and you want a rear 4 link setup thats gonna hook something nasty check out www.teamzmotorsports.net. Look at the upper control arm kit with relocation, and the double adjustable lowers.
Not sure if this is another question, but Ford is not gonna add things like upgraded LCA's, because it is too expensive and adds too much NVH to their cars. Even the GT500's have many "comfort" short-cuts to sell to the general public. Very few go out and race a production car, as most will buy/build a dedicated one that will perform MUCH better.
When I say "race cars", I am referring specifically to those cars that are dedicated to open-track (some exceptions, to be sure and mine falls in this case). These cars are required to have roll-bars, most of the time and would be a wise idea to do so anyway.
If someone is hardcore into AX or open-track, a new "K" is mostly beneficial for power-adders, weight loss, mechanical access and geomentry benefits. It is certainly stronger and can ONLY help to strengthen the structure, but the S197 does not see as many benefits of the earlier Stangs.
Jazzer
The control arms have all of the bushings except for the ones that are inserted into the axle housing. You're okay to use the factory axle bushings at moderate power levels, but I like to see those bushings upgraded to spherical bearings at around 5-600hp. Of course, the suspension will articulate more freely with the sphericals even at lower power levels, but people typically only upgrade the bushings when they NEED to, because of the slight increase in road feel.
