Traction Control: Stuck On
Old Jan 2, 2012 | 12:05 PM
72MachOne99GT's Avatar
72MachOne99GT
2010 Blue Ball Award Recipient
Default Traction Control: Stuck On
My '99 which has roughly 107,000 miles is unable to disable traction control.
I'm not throwing any codes, and for the most part the car seems to be running well.
It has happened occasionally that I'll have an ABS light on and the TC will be off (not recently) but I assume this is a wheel sensor or soemthing, and when the ABS light comes on, TC is always disabled.
I simply press the TC button behind the shifter and it won't turn off.
Anyone else had this, or know a remedy?
Old Jan 2, 2012 | 01:03 PM
Andy13186's Avatar
Andy13186
is the light on the button on?
Old Jan 2, 2012 | 01:05 PM
99GTvert's Avatar
99GTvert
is my username.
Have you tested to make sure it is still on? My bulb took a **** (or a plug is ****ed), but mine can still be turned off.
R1nStang's Avatar
R1nStang
sounds like the connector to the button may have come loose...or a frayed wire. i'd check that first.
Old Jan 2, 2012 | 01:53 PM
72MachOne99GT
I'm certain it's not disabling.
No lights are on, and the system still kills the car under any slippage.
Makes it a pain in the *** to accelerate from any unlevel intersection.
I suppose I'll pop off the plastic cover and see if anything looks bad.
Old Jan 2, 2012 | 01:56 PM
72MachOne99GT
Edit: I mean now that it's snowing.
I have much better luck w/o TC in any accumulation.
Old Jan 3, 2012 | 07:25 AM
Supercrewzin01's Avatar
Supercrewzin01
Check all your fuses under the dash and under the hood. Replace any of the fuses that are blown.
mrtrodonet
Sep 19, 2020 03:12 PM
ChampInSD
Oct 2, 2015 04:55 AM
jstrothe
Sep 24, 2015 12:17 PM
rafotree
Sep 22, 2015 03:55 PM
mikesr4565
Suspension
Sep 21, 2015 10:26 AM
