Intermittent failure to start
Old Feb 19, 2012 | 06:11 PM
Shampue's Avatar
Shampue
Default Intermittent failure to start
I have a 4.6 with 58k miles
Every now and then when I start the car it will fire up but immediately idle very very slow and quit. tonight it did it 2x in a row.
It doesn't happen all the time and it doesn't appear to be related to engine temp.
No SES light and no other signs of problems
Any thoughts on what may cause this and what I can do to correct it? I was thinking injector cleaner.
Old Feb 19, 2012 | 06:32 PM
EddyG's Avatar
EddyG
mine used to do this it was my choke. but mine only did it when cold
Old Feb 19, 2012 | 06:38 PM
Shampue's Avatar
Shampue
Engine cold or outside cold?
Its under 35 degrees here now. Mine seems to do it either when the engine is cold from say an overnight parking, but it also sometimes does it after I drive across town, fill up with gas and try to restart the car.
Old Feb 20, 2012 | 02:39 AM
BLKSTANGER's Avatar
BLKSTANGER
Sounds like the fuel pump is dying to me.
Old Feb 20, 2012 | 06:35 AM
EddyG's Avatar
EddyG
It did it when the car was cold.
Old Feb 20, 2012 | 09:02 AM
cliffyk's Avatar
cliffyk
TECH SAVANT
99.44% of idle problems are Idle Air Control valve related--they call it that because that's what it does...
Old Feb 20, 2012 | 10:18 AM
Shampue's Avatar
Shampue
Thanks Cliff
$52.00 part. Just replace it or can I clean it?
Old Feb 20, 2012 | 10:25 AM
cliffyk's Avatar
cliffyk
TECH SAVANT
Some have reported success cleaning it with TB cleaner, however most often that is at best a temporary fix.
Ford says:
Old Feb 20, 2012 | 10:26 AM
Shampue's Avatar
Shampue
As usual Cliff. You're the man! Thanks
zsmart
Convertible Tech
Feb 29, 2016 08:33 AM
1TUFF302
Nov 5, 2015 04:02 PM
StalkerGT
Sep 25, 2015 02:41 PM
zanemoseley
Sep 6, 2015 12:58 PM
5.0 kevo
Sep 3, 2015 06:24 PM
