overheating problem?
Old Feb 19, 2012 | 10:22 PM
mustang7777's Avatar
mustang7777
Unhappy overheating problem?
hello i have a 98 gt and i recently changed the water pump because it was leaking the car ran good after that so i took it out and ran it pretty hard then it overheated now it runs rough and overheats in about 20 minutes and i noticed there is coolant in the first spark plug well on the driverside also some white smoke coming from driverside tail pipe. not long before this i replaced the intake manifold with the aluminum crossover used new gaskets but didnt use any rtv sealant so was wondering if maybe the coolant is leaking from there. any help or advice would be appreciated.
Old Feb 20, 2012 | 10:10 AM
mustang7777
anyone?
Old Feb 20, 2012 | 12:05 PM
mustang7777
update. i just went out an drained some oil from pan and there is coolant in the oil. also checked the coolant but no oil in there.
Old Feb 20, 2012 | 12:08 PM
Shampue's Avatar
Shampue
Coolant in the oil could be a cracked head, bad head gasket or a leaky intake manifold gasket.
Old Feb 20, 2012 | 06:08 PM
96meangreengt's Avatar
96meangreengt
Did the new intake happen to be a PI inatke by chance. because you have to use rtv sealant on ethier side of the front runners to block of part of the coolant passage, if not you will get coolant in your cylinders
Old Feb 20, 2012 | 09:49 PM
mustang7777
nice car meangreen, how can i tell if the intake is a pi intake? my car had an all plastic intake and it had a leak on the crossover part so i went to a junkyard and got a intake with the aluminum crossover from a crown vic. if it is the intake leaking is their a better gasket i can use? the kind i have on there is the plastic with the rubber built in it on both sides. should i use rtv?
Old Feb 21, 2012 | 06:49 PM
mustang7777
ooooo
Old Feb 21, 2012 | 07:58 PM
96meangreengt
What year crown vic was it?
Old Feb 23, 2012 | 07:57 PM
mustang7777
i think it was a 98 crown vic.
mungodrums
Sep 29, 2015 09:18 PM
stangin1996gt
Sep 21, 2015 11:01 AM
yourmom6990
Sep 14, 2015 10:52 PM
MusicCity615
Sep 12, 2015 07:05 AM
96stang3.8
Sep 10, 2015 06:42 AM
