MAF Question
I have a 02 Vortech supercharged mustang.. Im gettin around 8lbs of boost. I wanting to put a smaller pulley to get around 10lbs. My mass air peter is at 973 counts at 6000.. Would adding two more lbs of boost peg my mass air.. I think pegging is 1,023 counts.
You said peter, lol.
To go beyond that limitation you have to scale the MAF curve of the new MAF to keep the interpreted air flow under 3838.2 lb/h, and then reset the standard air charge and and injector slopes by the same factor.
For example if you were running the Bazooka 3000 MAF, which maxes out at 7026.2 lb/h, you would have to:
- scale the MAF Transfer Function by 3838.2/7026.2 or 0.5463 (54.63%);
- scale the Standard Air Charge (stock value is 0.0015531 lbmass of air) by the same amount, 0.0015531 * 0.5463 = 0.0008484 lbmass air;
- scale the Air Manifold Volume (stock value is 0.3399 ft³), 0.3399 * 0.5463 = 0.1857 ft³
- scale the Low Injector Slope (assume 60 lb/h injectors), 66.0 * 0.5463 = 36.06 lb/h;
- scale the High Injector Slope (assume 60 lb/h injectors), 60.00 * 0.5463 = 32.78 lb/h;
- scale the Injector Breakpoint (FRPP 60 lb/h value is 21.4875 μlb/crank revolution), 21.4875 * 0.5463 = 11.7386 μlb/rev;
What you will need to do is get a higher capacity MAF, if you start ingesting more air--and then make the changes listed above to re-scale the tune.
To make those changes you will need a low-level tuning system like SCT Advantage or Delta Force Commando.
I know that an SCT handheld would let you load a scaled tune created with Advantage, however I do not know what sort of tweaking it would allow.
The Lightning 90 mm (red curve below) pegs just at the 3838.2 lb/h (1741.38 kg/h) limit of the EECV PCM:
Any idea what the specific PID is for Standard Air Charge is? I don't remember seeing that anywhere in my tune (albeit, my strategy file has -no- descriptions in it).
In your FBFG2 strategy the Standard Air Charge is a unsigned Intel word at offset 0xE6DE. In some tuning systems it is called the "displacement of one cylinder" with the value being units of mass (English or metric) of air at STP.
In EEC Editor is is called cid_airmass_for_one_cyl...
jwog666
Dec 27, 2021 08:09 PM
treesloth
Sep 28, 2015 07:03 AM
