Ford Racing B or C Springs?
The only difference is the front spring rate, correct?
Which of these springs would be best suited for a weekend toy. Don't plan on racing it. I just take it out on weekends with the wifey.
Thanks guys!
Thanks guys!
I think the "C" springs are like the Bullitt or Mach1 springs.
If that is correct, I highly recommend those for your purposes. The drop is only around 3/4", but the handling is much better. What struts/shocks are you putting on?
I had my C springs put on back in late 2008 no complaints for city or highway driving at all so far. http://www.moddedmustangs.com/forums...-question.html
I run the B springs, which are fine for me but it is rough on the roads I drive on since there are a lot of pot holes. I also paired them with Bilsteins which make it a little more stiff. It really will depend on where you are driving it and probably the match of struts.
I don't know about the B springs, but the C springs will not ride harshly. The stock Bullitts and Mach1s come with them. You might find the ride isn't quite as good with your original factory shocks. Plan on upgrading your shocks when you can to improve both the ride and handling characteristics.
squishbang
Suspension
11-02-2015 03:42 PM
96, cobra, convertible, csprings, difference, ford, frpp, lowering, mach, motorsport, mustang, racing, running, springs, v6
