Exhaust/02 sensor help
I took off my off road h pipe today and the inside of the pipe was all black. I had my CEL on as well and the car did keep stalling at a stop. All the o2 sensors are pitch black. Are they still useable?
What are the codes that triggered the SES lamp?
You can bench test a narrowband O2 sensor with a propane torch and a multimeter...
Also are the front and the back sensors the same?
How do I know where they go?
Yes--The stock sensors are the same except for the pig tail length and connector keys.
The stock sensors are the same except for the pig tail length and connector keys. You may have to cut one or more keys out of the connector to make them fit. There are three connector configurations:
passenger's side (bank 1) front
driver's side (bank 2) front
The front connector's keys are the same; don't let the pin numbers on the front's fool you. The harness wires have the same functions.
passenger's side (bank 1) rear
driver's side (bank 2) rear
The rear connector key's are different from the front and from each other.
So, to use the rear sensors on the front you will have to cut off male connector keys as necessary...
2. Does each o2 sensor have to go in a certain location or are they universal?
Thank you. Now, i cut the front o2 sensor pigtail in half. There are black, gray , and 2 white wires. How do I know which white wire goes with the other one one the opposing side? (I'm soldering it together)
What you have there is an after market sensor, probably Bosch (see below)
The white wires are the power to the sensor's heater. The heater is a resistance type unit, non-polar and isolated from the sensor body--short answer, it doesn't matter which white wire connects to which. If it did i would be pretty stupid to make them the same color, wouldn't it?
The black wire is the sensor's output signal, the gray the signal return (ground).
You may find you cannot soft solder the wires because often they are made of Monel, a nickel/copper alloy. You will have to silver solder them or use crimped butt connectors, which if done correctly is just as good as soldering.
Fill the connectors with dielectric grease, and use a good full compression crimping tool like this one from Harbor Freight:
If you have a cheap set like this:
Smash them with a BFH and toss them in the ocean or a deep river--or give them to someone you do not like, that's always fun...
jwog666
12-27-2021 08:09 PM
TfcCDR
09-14-2015 12:08 PM
